We will be moving shortly and I will no longer be able to have a trickle charger on the TW. I will be stuck removing the battery to charge it (either a single battery or keep a 2nd one on a trickle charger to replace it with). I was looking at the Ballistic Performance EVO2 Motorcycle Battery Quick Disconnect Kit and was wondering if there are other options available. I thought about just cutting out the battery terminal cables so I could just loosen the battery terminal bolt and slide the cable off the batter to remove it for charging. Any other ideas out there?
I think I've read about the Ballistic stuff frying batteries. Wish I could remember where. Most likely here or ADV.
