The Bighorn2 is a lightweight answer to the original Bighorn.
The ATV guys figured out pretty quick that all that weight was eating horsepower (times 4, in their case). The Bighorn2 addressed this and the original Bighorn remained in production to satisfy the needs of hunters, heavier 4x4s, etc.
I have ran both. both kicked butt when aired down. All of them will tend to climb themselves in corners due their less rounded profile.
Any chance that is what you're interpreting as stiffness? I currently run a Terracross and they all do it. Of the three that I have used I prefer the BH2.
The other possibility is that the stiff stock shock is reacting to the weight of the tire and spanking you in the butt. Are you running a stock shock and swingarm?
Thanks. I did get from Maxxis tech that weight reduction for racing was the purpose for the 2.0 but I didn't get much out of them on shape or stiffness.
My perception of stiffness comes from running BH Originals on a Rokon at 3.5 PSI that are 2/3 flat at 0.5 PSI where the Duro is standing proud and tall at 0.5 PSI. And there are lots of rocks, small and large, in Arizona where I ride. The Duro tends to just set and spin on large flat rocks, even at 0.5 PSI, where the Rokon would putt right over. Plus, I have ridden a regular dirt bike with trials tires on the rear for years and the Duro will spin where it will not. The Duro is brand new and I'm displeased enough to toss it for another.
No problem with getting kicked in the butt with the stock suspension. If I want to go faster I ride the KLX. I have a 70T rear sprocket on the TW so where I go with it I don't really need better suspension.
The big thing I am concerned with before I order is that the 2.0 is as rounded as the BHO. My perception is that the squarish design of the Duro leaves the sidewall straighter which adds to the stiffness.
I would expect the skinnier lugs on the 2.0 to allow more flex than the BHO if everything else is equal. Since you like it best, it sounds like it probably does flex more. Conforming to what is under the tire is the key to traction. And from what I've read here, it sounds like the 2.0 will not require swing arm lengthening.
Thanks for the reply. I think that's enough to spring for the BH 2.0
Harold
PS: BTW, the TW had a "Golden Boy" DS tire on the front when I bought it. I just mounted a MT43 on the front and it's night and day. The front actually goes where I point it now and stays there.
