The mother of tw big bore links
http://www.google.co...lient=firefox-a
A fellow at adv went bigger but had mixed results (See Below)
http://www.advrider....ad.php?t=490048
You are going to have a hard time bumping the TW200 up very far. It is such a short stroke engine that even doing a 3mm overbore for an XT225 piston is only going to take it up 214cc. You are looking at a 5mm overbore of that little cylinder just get it up to 225cc. And remember, you are basically talking about a 125 engine that is already bored and stroked to go from 124cc to 196cc. So reliability may be an issue if you try to go much larger.
Back in the day I had my 200 overbored to accept an XS400 piston. That was a 2mm overbore (67mm to 69mm) and the mechanic figured we were about at the limit of what the liner would take with that. That 2mm bore took it from 196cc (same as the TW200) to 208cc. The XS400 piston has a higher compression shape so we had to make a pretty thick base gasket to get the compression down enough to run on premium pump gas.
After that it was a quite a headache to get it jetted right for the additional displacement, a Supertrapp muffler and opened up airbox. It was quite the little screamer when we got through with it. But it was a LOT of work getting the jetting dialed in.
And we never did get it completely sorted out so it idled well. Ultimately it provided very little benefit over just adding a pipe, opening the airbox and rejetting a stock motor.
So, IMO, the bottomline from my experiment: I would leave well enough alone and just try to get the most you can from the stock motor. In fact, I still have that bike and plan to eventually put it back to stock if I can ever find the time to work on it. It was a much happier engine in stock form with the Supertrapp, airbox and jetting mods.
If I had wanted more than 200cc's I would have got a
2008 Yamaha WR250R
Price $5899 Dry weight 286 lb. Wheelbase 56.3 in. Seat height 36.0 in. Fuel mileage 51.7 mpg 0–60 mph 7.4 sec. 1/4-mile 15.47 sec. @ 81.90 mph
Horsepower 25.2 hp @ 9200 rpm Torque 15.3 ft.-lb. @ 8200 rpm Top speed 85 mph
