Thanks, I could tell from the dual shocks that this was leading edge technology. Go Skyteam!
Once you are back in USA you can get the somewhat similar 196cc Hurricane.
Hurry special sale price, 9 hours left!
Probably is mopre fun as a beach bike in Brazil than as a run-around pit-bike in your Boise Basin.
| | | | | | Want Extra Savings? | | Text: SAFER To 1-866-606-3991 For Extreme Steals & Deals! | | Sign Up For VIP Steals & Deals... | | | | | |  | |
LIST PRICE: $3,098.95
REGULAR PRICE: $2,496.95
JAN 31st 9 HR. SALE: $1,299.95
You save $1,799.00! |
Product Code: BVP-HURRICANE-200XX |
eatures & Specifications:
- Displacement 196cc
- Starting: Recoil Cord
- Spark Plug Type: Torch - F7RTC
- Cooling: Air cooled
- Ignition Type T.C.I
- Cylinder head config.: OHV
- Number of Cylinder: Single
- Combustion Cycle: 4-stroke
- Bore and Stroke: 68 x 54mm
- Compression Ratio: 8.5:1
- Rated Power 3.8kw @ 3600rpm
- Rated Torque 10Nm @ 2500rpm
- General Information
- Top Speed 25mph
- Lights: Front Headlight Continuously on
- Drive System Type: Chain Drive
- Transmission : CVT
- Suspension: Front Hydraulic shock; Rear Shock;
- Front & Rear Disc Brakes
- Front Tire Size AT19x7-8: Rear Tire Size AT19x7-8
- Gas Tank Capacity 1 Gal
- Fuel type: Unleaded 87 octane or higher
- Oil Capacity .53qt. (.5L); Oil Type SAE 10W-40
- Crate size: 60’X18’X30’
- LXWXH: 66.14’ X 31.5’X 38.58’ (1680mmX800mmX980mm)
- Wheelbase 45.28in. (1150mm)
- Vehicle Wt. 167.5lbs
- Gross Wt.: 200lbs
- Weight Cap. 200lbs
- Ground Clearance 6.7in (170mm)
- Powerful 196cc OHV engine
- Front and Rear disc brake
- Equipped with Torque Convertor, CVT drive
- Front and rear suspension
- Aggressive large 19X7-8 front and rear tires
- Stylish fenders
- Headlight
