The 'Yamaha Blaster mod' is one that is semi-controversial on this forum as not much is known about it's handling characteristics. It also discussed in this post.
The Blaster shock is shown here on the left, with the stock shock on the right.
Some have had luck directly bolting the shock into their TW. I had to have a bushing made for the upper mount, as the blaster shock's bushing had a much larger inner diameter. I assume that it might matter what year the Blaster shock comes from, or whether it's a front or rear shock.
I never cared enough to do more research into the matter.
Things I had to contend with:
The height difference is evidenced here. Before:
After:
Now that I've got some miles on the TW, I can give some actual thought to the positives and negatives of the Blaster shock.
Honestly, I've really enjoyed the ride quality of the Blaster shock so far. It handles fine on dirt and pavement and the squat is just about the same as the stock original. I have not done much trail riding yet so I can't comment on how it responds to washboard type riding.
One thing I wasn't expecting... I miss the seat height of the OEM shock!
One of the things that really made me fall in love with the TW, now that I think about it, was how approachable of a bike it was. The low seat was so non-menacing. It is much less approachable when you have to stand on your tip toes to mount up! And I'm 5'11".
Another thing you have to expect: having a high rear and stock front means that you're going to be pushed into the tank when you hit the brakes. I liked this less than I thought I would. I didn't think I would mind it.
For this reason, and because I want my shorter friends to enjoy the bike as well, I'll probably revert back to the stock shock.
There is something to be said about walking over to a short bike and easily hopping on. I miss that part of my TW and am going to get that back!
I know Mike and treybad have both acquired Blaster shocks and am wondering if they'll chime in with their feedback once they've had a chance to try out the shock.
(MODS: I accidentally mis-spelled the title line. Could you please change title from Blast to Blaster? Thanks!)
- Kickstand length (your OEM stand will no longer reach)
- Chain length (you will need to add some slack to your chain)
- Brake rod will now interfere with passenger pegs
After:
