I noticed that on my Yamaha TW200 the bleeder valve on the front brake is snapped off.
My questions is, how can I remove it easily? I was thinking a reverse drill bit might work the best.
Another question. If I remove it, I guess it means bleeding the front brake?
Banned
Is it broken flush with the caliper? A reverse drill bit might work. Maybe an Easy-Out? Tap in a tight-fitting allen or torx? Coax it out with a chisel and hammer? If the entire head is broken off, and it isn't real tight, maybe just pushing down with a finger tip and twisting?
It's broken a little below the caliper.
I have to take the bike in for a base gasket replacement, so I'll see what they recommend.
I would ignore it and fit a new banjo bolt with a bleed nipple in it. I've drilled these out before and it just isn't worth the hassle, especially as you can ruin the calliper.
Yea, since it not leaking, I'm going to ignore it for now. Might get time int he Winter to remove and replace it.
