It’s the electrical resistance of the indicator bulbs that triggers the flasher unit to blink — LED’s have a lower resistance, so there’s not enough to trigger the flasher
Let’s say you have four bulb elements at 15W each, that means that at 30w (two on each side) they will activate the flasher. So now you have LED’s at (for instance 3W), 6W resistance ‘aint gonna cut it if the flasher unit is looking for 30W to trigger
So you now have to dial in your flasher unit. The usual way is to simply buy a new flasher unit from Ebay (cheap as chips) which will react to a lower load, but you have complications in the other LED’s in your hand guards
What you need to search for is a fully adjustable flasher unit rather than a “fixed rate” one. This will typically be able to be dialled in to however many Watts (resistance) you’re LED’s are taking — it’s a slightly more expensive way to fix this, but should work just fine. Just stick the indicators “on”, get in there with a screw driver, and turn it one way or the other until you get the blinking rate you require
There is a slightly cheaper way of doing this, that involves diodes, wiring, soldering, and a degree in electrical engineering — and is not recommended for the uninitiated
You don’t mention whether or not you are keeping the (USA) constant amber running lights on the front indicators, but bear that in mind on your wiring
Welcome to the house of fun …..
