this is a bit of a cautionary tale about brake shoes de-laminating while driving, and the value of preventative maintenance checks.
driving the bike last week, i had experienced what i thought was a momentary and severe loss of engine power while going down a long hill (with a turn at the bottom and a car behind me...).
it cleared, but i now think that it was in fact a chunk of brake shoe lining coming off and the sudden drag felt like the engine bogging. i resumed driving, the brakes dragged a little after that, enough to heat up, and i had to slack the cable off on the way home.
then, the other day, about 15 miles out, my front brake started grabbing erratically. i pulled over, removed the lever to give max slack, and headed disappointedly back home at half speed.
anyway, i got safely home, said a thanks to the various deities involved with the protection of fools and travellers, hoisted the bike up off of the rafters and pulled both wheels.
overall, i was surprised by how many little things had drifted towards becoming problems, and it's a reminder to be a bit more proactive on preventative maintenance. entropy happens.
here's what i found and did:
both front shoes totally de-laminated. back shoes fine.
i checked both sets under two years ago. neither appear to be oem, though only ~12k fairly easy miles on the 1990 bike.
no brand name on failed shoes, but numbers 3 y1-00 / jbd-41fg L.
i must say overall it's a really sweet brake design. simple, simple, simple.
front tire preasure, = about 5 psi. rear = 20psi. i usually run both at 25-30 but had not checked them in ~3months even though i know the front has a slow leak. i know, i suck.
the low front air and maybe the dragging brake had worn a surprising amount of meat off the "just-out-from-the-centerline" lugs on the front tire. in retrospect it was handling differently, but i use the bike sporadically on varied terrain and it's surprising how much the front tire retains it's shape without much air. (it's a very stiff luggy "vee rubber 69r" made in thailand.)
continued
continued
