I finally got the bike out after the snow in Austin and this is what I have found so far and what I might need. If y'all could reply back with the links or contact info as to how I can go about purchasing the following parts so I'm spending less time hunting on the internet and more time with the bike. Thanks!
Please send your best links for the following items needed: Again its a 1992 with 24K mi.
ALSO, if anyone has anyone has any of these items and would like to help me, please let me know!
1. The rear tire leaks air at the spokes. I read there is a tube inside the (Bridgestone) tire. Please send link for tube and recommended tire since the tires are from 05' I think. Ill replace the front tire as well so a rec on that too. Someone mentioned (Shienko) mispelled...
2. Complete oil change kit. synthetic oil, O rings, filter (paper or oem?), new oil plug, new bolts for the oil filter cover (the orig ones are bad)
3. Carburetor. OEM or aftermarket? $300 or $30?
4. New air filter and air intake boot from filter box to carburetor and new boot from carburetor to engine. New bolts as well.
5. Another member sent a link for a new kit set of stainless bolts $20 from Alloy Boltz. Anyone have thoughts? It does not look like its got everything...Most of the bolts seem to be somewhat chewed up.
6. The headlight and tail light do not turn on. Could be just a bulb? Please send a link for these, Ill probably just get the OEM at the local parts store. The bike came with front blinkers that are currently working but no rear ones. Ill need the rear ones. Also currently the bike does not have a battery if that matters. Already ordered a bat. If someone has a front and rear light kit that is sitting around after going to LED let me know....
Appreciate the help...
