It is not dip finish. That would be pretty expensive I've heard. No, this is sticky back plastic paper. I got it here;
CamoSKINZ - Now Entering Camo Country
They make a permanent and a removable version. The permanent is cheap, the removable a bit more expensive. I went with the removable. It also stretches some. I bought a brand called "Kings Shadow" in a pattern called "Mountain Shadow".
I got a 2' x 5' piece and it was a bit too small. Look close at the front fender; it's pieces. That is a white fender that I put the camo on, then I masked off and sprayed with 'Plasti-Dip' spray paint stuff. The neat thing about the spray is that it will peel off like a sunburn when you want, but has plenty of UV properties and will stay there as long as you wish. If it gets damaged, just reapply the spray. I've seen whole cars done on youtube with the stuff. Some folks use it to spray their wheels to protect from salt damage during winter.
Anyways, I made my 2x5 piece work. Took me a couple days fussing with it. Stretching and pulling, nipping and tucking. I have no idea how long or durable it is, but for $50, it's worth the effort.
My goal is to be as stealthly as I can get. I've already quieted down the engine rattle by putting a stainless steel XT225 header on there. The thicker wall makes the motor much more quiet.
Not in the photo, but I will write up someday, is a copper 3/4" 45* elbow with a 2" 3/4" copper stinger on it. This directs the exhaust down towards the ground and makes the bike another several db quieter. I got another db or two quieter by using Rotella oil.
