1 - 15 of 15 Posts
I ordered some new sprockets and a chain as the '93 I just purchased is likely still running the original parts and they were looking a bit worn. I got a standard 14-tooth front sprocket and a 47-tooth rear, figuring I'd gear it up just a tad for better street performance.
I called my mechanic buddy over to do the install, and he noted that on this bike one must remove the crankcase cover (and drain the oil) to get to the front spocket (which I guess is more complicated than on some bikes where getting to the front sprocket is much simpler he says.) Thus, he's recommending that before we get started we order a new crankcase seal (as the old one will likely come off in pieces he says, as well as a shift-shaft seal (as it too is likely worn and might as well replace it while we are in there.). He also noted that where the chain goes around the rear sprocket there is a plastic guide and wondered if it should not have a bottom part on which the chain rides (it does not and looks like this has worn off or perhaps another owner cut it off?) Does this all sound legit to you?)
So, before we can even get started, it means yet another trip to the dealer for parts, (and waiting until Tueday as they are closed on Mondays). Then, we cross our fingers and hope the parts are in stock or it's even more waiting. I'm also wading through electrical issues as the battery won't charge. I replaced the regulator/rectifier but that didn't lick it. We now suspect some bad wiring connections which also means more parts.
Arghh! Such are the trials and tribulations of buying a used bike. I'd like to be riding it rather than waiting for parts!
Your mechanic buddy is just being thorough. Changing the seals is never a bad idea, and the odds of wiping out the cover gasket are pretty good given your bike's age. Better to have one on hand, and since you're ordering one, might as well get the seals.
I do think he's mistaken regarding the chain rubguard, though. The portion that runs on the top of the swingarm should be about 2 inches longer than the lower part. The lower portion is only about an inch long and squared off as you describe.
One trick that works fairly well for me is to glue the gasket to the COVER side with a VERY light coat of Permatex non-hardening Form-a-Gasket, then lighty oil or Nevrsieze the engine side of the gasket. 9 times out of 10 I can reuse the gaskets if I lightly tap the cover with a rubber mallet until the cover comes free on its own, rather than forcing or pulling the cover off.
Don't forget to replace the seals on the drive shaft the sprocket is on. Especially the outer seal. I didn't and had to take it apart again just for the seals.
Also, after you take the chain off and before you remove the side cover wash all the dirt out from around the front sprocket, where red arrows point.
· Banned
Your mrchanic is doing a thorough job. Be thankful. replace the shift shaft seal, both the countershaft seals, and the cvover gasket. With new sprockets and an o-ring chain you'll be good for 20,000+ miles. It would be a pain to redo all that work because of a bad seal. 6 months from now. Kind of like always putting in a throwout bearing with a new clutch.
+1 Yup! Swap front sprocket at oil change time. New gaskets/seals are always a good idea. And this is also a good time for a quick check of valve clearance and timing chain adjustment.
Hey... ya already have the engine open, look around a bit, maybe find a problem before it bites ya.
I'll be doing all these seals, gaskets, chain, and sprockets very soon (maybe even the clutch)... Is there a list of part numbers that we could put together for this job? That would make going to the dealership a little easier. AND, is there anyone one here with dealership connections / discounts on stuff? I'm part of a Land Cruiser forum (ih8mud.com) and there are many vendors with OEM parts for much less cost than going straight to the dealership...
Thanks!
· Banned
Thanks!
www.stadiumyamaha.com There are others on the internet.
· Banned
Most of the on-line parts websites use an adaptation of the OEM computerized parts catalogue for ordering. You can look up your own part numbers using those sources.
On the parts diagram I see two crankcase gaskets. Do both need to be replaced? Sorry I'm doing the same thing at the moment and didn't know which to order.
If you are just replacing the sprockets and chain you only need the left side gasket. #3 on the Bike Bandit parts diagram.
Ya shouldn't have to touch the right side case cover.
stupid me. i thought the two cases there didn't have anything in between since they don't on the diagram for a second.
i'm missing a link, i'd like an award.
Heh, heh... yeah, the stuff that goes between is on another page.
First time I was looking for that gasket it was my first time on that site... it took me a while to figure out I needed to scroll down.
I remember shouting "where's the #*@$ left side!"
1 - 15 of 15 Posts
