1 - 13 of 13 Posts
The 1998 TW we just bought has a Cheng Shin 180/80-14 back tire. I've never seen one advertised. I thought the OEM Bridgestone was the only rear knobby. This CS is about 1/2' wider than the Bridgestone. It also says it will inflate to 32 psi for a total load of 935 lbs. YIPES!
Cheng Shin on left. Bridgestone on right
now that i think about it, i think i have the same rear tire on my bike...never really paid attention to it cause the previous owner had replaced it so all i do is adjust air pressure...
The Cheng Shin tire for the TW hasn't been available for several years.
The 92 I'm trying to put together has a CS on the rear.. Looks good. Hope I get to see how it wears soon...
I bought two brand new CS tires off a guy on ebay for the price of one BS tire. Hopefully I am set for rear tires for the rest of this year.
Banned
Sled, that looks like the original Bridgestone.
"....The Cheng Shin tire for the TW hasn't been available for several years..... "
I don't believe that the CS brand is available at all nowadays....perhaps leftover remaining inventories only. I've used them on several RD350/400's years back,sort of the' poor man's Metzler M33'....very good adhesion,short lived because of that;but very inexpensive to replace. Time sensitive,too-use 'em before thay git harder than a mummy's pecker!!:D
I haven't had a change to ride the "new" '98 TW with this Cheng Shin, yet, to see if has hardened-up. The bike is now ready for its first test ride after 4-5 years of storage. But, my world (Missoula, MT) is covered with ice. I can barely walk outside.
If stored out of sunlight they should be fine. In the past I have used old "new" tires and once the surface is worn down a little to good rubber they were as good as one just off the shelf.
Seriously,I'd like to read a definitive article of storing/preserving tires for lengthy periods prior to use. The usual obvious things such as storing them in a moderate climate,away from UV are a given. I don't think any such paper exists,at least not nowadays........
Discussion Starter #13
I have thought about hitting the surface with a palm sander. If the snow would go away I'd do it with a quick run to the store. Grrrr.
1 - 13 of 13 Posts
