1 - 8 of 8 Posts
Hello fellow TWs. I just bought a brand new 2016 TW in March 2017, it had no miles. Turns out I could not take delivery because the clutch was sticking. Turns out the clutch indentation rod was not installed properly from the factory. After two weeks from the day I bought it (and never had it), I finally picked it up. I road 22 miles and the clutch failed. I called Yamaha and they helped me adjust the cable over the phone. It worked. I drove two miles and it failed again. I called Yamaha and they helped me get it running again. I drove one more mile and the clutch failed again completely, no clutch. I was at 24 TOTAL MILES at this time. I got the TW back to Yamaha and upon inspection, the clutch indentation rod had popped out of position a second time. I drove the bike very very carefully and I had nothing to do with the clutch failing. Now Yamaha just wants to fix it again and give it back to me. I say that's not such s good idea. Anyway, I do see other mentions in the forum about indentation rods. What should I do, need advice, two week old bike with 24 miles and several clutch failures that are INSIDE the motor? Thank you.
Hi TW2000 and welcome to the forum!
Sorry to hear about the problems that you are having, but these are clearly not your fault. I am not sure what the problem is but it also sounds your dealer doesn't know either. Put the burden on them to come up with a solution that is fair and satisfactory to you - even if that means replacing your bike.
Brian
Hmm... you are the second person recently who has had issues with his dealer. If they keep giving you the run around about this, don't be afraid to contact a lawyer. I hate to say that, but sometimes consumers need help.
clutch spring photo
http://tw200forum.com/forum/attachments/technical-help/9574d1410022483-clutch-adjustment-100_4375.jpgThough this is not the cause of your problem, it may be a visual clue as to the competency of the shops service dept... Note how the clutch arm return spring curves up and over the lever. I (we) have noted that many bikes come right off the showroom floor with that spring 'hanging' loose. This makes for a very mushy feel at the lever. I would suggest you use this as a visual clue should the dealership give you a call and suggest your machine is fixed and ready to picked up. Look for and at that spring..... If it is not in the position you see in this photo, it likely came from the factory that way. I then would be inclined to point this out and suggest you no longer have faith in bike or the shop's ability to fix it properly. At this point, you would only feel comfortable with a new bike, or your money. The shops loss will be minimal, likely a few dollars in parts and some labor to keep a mechanic busy on a slow day and then the bike would be sold as a demo. Don't be resistant to spending a couple of bucks talking with an attorney.
had the same "spring not attached" issue, caught it and fixed it about mile 3. My clutch still doesn't seem to return smoothly almost like something is hanging or cable is sticking. sound like the same issue? Im a noob to the tw's and hoped that some experience can save me some headache with smoothing out the clutch.
There is an internal clutch adjustment made by turning rod #9 left or right and then locking it in place with the nut the left red arrows points to. If that lock nut isn't tightened or comes loose the clutch will work for a little while and then quit. Maybe that is what is wrong.
From your description of adjusting the clutch and getting it to work a little while, which I guess you mean adjust the clutch cable, means to me it isn't the clutch cable causing the problem. And the fact the the clutch worked well at least part of the time suggests to me the basic parts are OK and that it is just a matter of putting it together correctly.
You got a love this group they see a problem and they unite and fix
1 - 8 of 8 Posts
