1 - 8 of 8 Posts
Just curious if there are any upgrade options for the clutch. I switched out the oil after break in with castrol 4t non synth and it is a lot better than the Yamalube. Now engagement is smoother but it is certainly not smooth and is a weak link in my opinion. I bet synth helps some but I wondered if it can be better? Is there any real adjustment that can perhaps help?
Thanks guys, my chain is adjusted and the clutch spring is on correct.
The clutch and notchy transmission are probably my biggest complaint about the TW. I'm going to order a new clutch cable eventually and see if that helps.
1 - 8 of 8 Posts
