1 - 4 of 4 Posts
So, since I got my TW200, I have been wondering what is wrong with the clutch lever (or me). I had to almost completely let out the clutch to get it to catch in first gear, which made taking off from a stop kinda weird.
Then I saw this:
http://tw200forum.com/index.php?/topic/431-clutch-slipping-check-spring/
Went out to my bike, and sure enough, that was the problem! Now I can split outta 1st like I am supposed to!
BUT, is this something that just happens from time to time or should I replace the spring?
Thanks - Bart
Thought is, whoever assembled the bike did not hook the spring up. Why this happens on so many bikes is hard to understand. Once hooked up correctly, I can't think of anyone that indicated it came off again. YOu should be set now. Gerry
I see, that is very strange. So if you are right, then both previous owners rode this bike around with that spring un-hooked for 3 years? Whacked. I mean, you can totally ride with it like that, but it doesn't feel right. Either way, I will keep an eye on it.
Thanks - Bart
Funny. I checked my clutch spring a couple of times, but I think I had over 600 miles on it when I finally found the the cable was never seated in the arm. It was just kind of sitting there on the edge. How it didn't fall off I have no idea. Dealers... (sigh)
1 - 4 of 4 Posts
