Hi all, I need to know the cranking rpm of an electric start model. Must be accurate within 10-15 rpm, no guesses allowed!
Thanks, Tom
Engine rpm or starter motor rpm? I’m not sure I can help but trying to think of how it could be observed or derived or calculated.
engine rpm with plug in but not firing. the pickup coil could be used with a very low rpm tachometer, or a scope, or a mechanical gauge on the end of the crank.
I have none of the above, but could I do a simple stopwatch and count the strokes by sound? Sorry if this isn’t helpful.
I really want to help because I think your CDI development has and will continue to help a lot of people who have exhausted most other options. The whole CDI thing should be filed under “Here be Dragons”. And I admire you for tackling it.
Plus I want one of your CDIs with a tach wire. Cheers and good luck
