Im gonna take a whack at answering your questions bases on current and growing knowledge. Also you mention you're looking at a moto4 225 head and mention head in your first list and because of wording I think you mean cylinder. Also to state my marginal credibility I do have a current 225 6 speed with 15k or so on it now and a 250 on the bench in the works. I have a thread currently going as I make progress. So........ the la sleeve 5679 will not drop into any cylinder you choose. It has a larger OD than the 225 cylinder sleeves by a fair bit. The height is almost spot on so Im not thinking it will need to be trimmed. The one issue I see is that the lip at the top is also a fair bit larger and will be over the holes that the dowel pins go into. When I spoke with LA sleeve last week they said they prefer to let that happen and rebore the dowel holes. The piston will never be the perfect fit when you're doing this. Sleeves come undersized a bit and don't have an internal surface finish until they are done. This is because pistons vary slightly and once installed into a cylinder things can distort slightly. So the process goes remove old sleeve, machine bare aluminum cylinder to fit new sleeve, install new sleeve, FINISH BORE AND HONE SLEEVE TO PISTON SPECS. I don't see at this time a larger oversize piston for future bores and personally don't care to much about that. Now also understand that you're going to have to machine the case mouth as the new sleeve is also larger than any 225 sleeve. Ive had this done before multiple times and its no big deal. you already know about the output shaft, left cover ect. Fair warning my current ttr225 cases 01 model I believe didnt come bored for a kicker. I had it done and its possible but your 04 cases may not either. By this I mean the right cover AND the actual right side case. I am waiting for a piston and crank pin and things are all headed off for final work. I am having LA sleeve machine and install the ya5679, ken occonor is rebuilding my crank shaft, case machining done local by a friend for beer, some one in California (twbrians recommendation) machined the output shaft, and I will do all the wrenching. LA sleeve quoted me 250 for the sleeve itself and all of the machine work to install it and ill tell you that's more than fair. Do yourself a favor and send it to the place that makes the sleeves and does it all day every day. Now a closing statement then Ill include some pics past and present....... Your TW will never be fast and this isn't cheap. If you want significantly more power buy something else that has more power and better chassis/brakes/suspension. I spent over 1000 bucks last time on the 225 and that's what i'm doing again on the 250. If you're brave and like to play press forward as it is a fun process, but be prepared to shell out and don't cut corners. Unless you know the condition I would (and did) replace all bottom end bearings, valves, valve springs, all seals and gaskets, cam chain guides, cam chain, and have the crank rebuilt (crank pin, con rod, big end bearing). I will be keeping a good thread on the 250 as I go since theres not as much info on it. Good luck
ttr225 cylinder with sleeve removed
Untitled by
dolphaxel, on Flickr
heres where the kicker goes and you can see its not machined
Untitled by
after I did the machining
Untitled by
