I'm hoping that I can get a little help. I am going to be tearing into my motor on a 2003 TW200 so that I can diagnose a little knock that I have. Since I will be pulling the top end apart I'd like to bump the HP a bit and install a 225 or 230 cylinder. Nearest I can gather, the 230 cylinder requires the cases to be bored out a bit. Does the XT225 cylinder require machining? Also, if I am going to be able to install the larger cylinder and piston will I still be able to use my head or will I have to change the head out as well.
I've tried to read as much as possible but it all seems to conflict a bit at times. I wish there was a single guide to parts exchanges for this bike.
Thanks in advance for any help that you can give.
