1 - 16 of 16 Posts
Banned
I went to Ace Hardware today and picked up 4 nylon 1 inch spacers at .49 cents each and 4x 6mm x 45mm bolts .79 cents each, I went with the nylon spacers I think it looks good.
Thanks Gary for your write up. 10452519_10202995721486070_900096573_o.jpg one inch lift. 20140423_175621 (1).jpg before lift. 10432326_10202995722686100_1105972083_n.jpg click to supersize!:pottytrain3:
HTML:
You may find that 1 inch was too much when you bottom out the front end. I think you can get away with 3/4 but not 1 inch. Please let us know. I've read 1 inch was too much and it still hits. Try springs instead of the nylon spacers. The springs will give and rebound back, the spacer may break the fender.
I have always liked the look of a low mounted front fender. So glad Gary came up with a way to keep the low fender and still have enough clearance. Good cheap mod. Atta boy Gary.
Banned
If I bottom out I will put it back to stock as I never find mud in the desert and I plan on putting the
.70kgmm
40% Stiffer then stock springs soon.
You may find that 1 inch was too much when you bottom out the front end. I think you can get away with 3/4 but not 1 inch. Please let us know. I've read 1 inch was too much and it still hit. Try springs instead of the nylon spacers. The springs will give and rebound back, the spacer may break the fender.
You are right Tommy. I bottomed out with 3/4" solid spacers and that is why I switched to springs.
http://tw200forum.com/forum/performance-customization/7455-spring-cushioned-front-fender-mounting.html
I remember your post B. I had put it on my list of things to do, but ended up with the high fender kit. Great thinking though.
Banned
I use 1" springs compressed to 3/4" to get mud clearance while still maintaining most of 6" suspension travel. Seems quite and stable at speed, rattles a bit on rough roads, survives big g-outs and a few suspension bottoming out o.k.
Banned
Discussion Starter #16
I fixed it! 10358858_10203002884585143_1557941751_o.jpg 10467502_10203003133671370_297787690_o.jpg 10449316_10203003137111456_1644215086_o.jpg Ace is the place! 10439226_10203002883465115_1883150118_o.jpg full compression. I used my 6mm x 45mm bolts but 6mm X 40mm would be better.
1 - 16 of 16 Posts
