1 - 14 of 14 Posts
I decided to do an experiment on the Clarke XT225 tank installation. Here is my attempt. This raises the front of the tank and lowers the back so it will have a better use of the fuel when low. Will need to field test it after finished to see if it actually works.
Used the hockey puck idea and bought a piece of 4" x 6" hard vulcanized rubber used for jewelry making. Seems to be about the same hardness as hockey pucks.
I heated up two areas of the tank and used 1 1/2" ABS as forms to put indentations so the tank would be able to be centered in the back and the right front fork would have complete travel. My tank was a bit more forward on the right front than the left front.
Also heated and bent the seat pan in various areas so that it would conform to the new tank angle and position.
Would like to give a big Thanks to all who those have contributed much information and innovation before starting on this project. Has helped a lot!
Also need to thank Admiral for the foam!!! It worked out perfect for this pan.
Would you mind taking a pic from above, as from the riders view? Think it’s the only angle I’ve never seen.
The petcock I used with a left side outlet is from a TTR90. Yamaha part # 5HN-24500-01
The tube is short so I will cut the tube and lengthen it about 1 1/4" to 1 1/2"
with some clear fuel line tubing. This will give me about 1 gallon of reserve fuel.
You can order them from Partzilla OEM.
I was curious about the petcock, thanks for identifying it.
Initial interest was that perhaps it might make inline fuel filter installation easier as well as facilitate tank removal since hoses can be longer, but maybe not?...glad you are pioneering heat modding this tank around frame and forks.
Being lower from tank the TTR petcock looks more readily accessible which is a plus.
That tank installation looks great and thanks for the detailed pics of the installation. Can you give us an update on the effects the new tank has on the bikes handling heavy in the front end and if it fills bulky in the saddle. A bigger tank may be something i would like in the future.
Exactly what I was looking for oldworld 124. Really appreciate it!
Again, it looks really good on the TW!
I expected the greater weight up high would be disadvantageous but one quickly adapts. One doesn't need to always have 4 gallons aboard either. Sloshing of a partial fuel load is also not as disconcerting as I had feared.
Discussion Starter #14 (Edited)
My take on the Clarke tank after completing a rigorous 90 mile run in very diverse types of trails.
I am about 6 feet so the bike is low for me. This wider and larger tank feels great. Using my knees to control the bike was very easy and just feels more natural than a stock tank. Did not sense any top heavy imbalance. No sloshing of fuel. Front to rear stability feels very good. The position of the tank also helps keep me from being moved too far forward when going downhill. I think taking the time to heat and form it to make sure it was centered to the bike helps. For me it is a winner.
I also heated the seat pan so it would sit on the frame correctly and form to the slope of the tank without any undue pressure. The seat cushion was cut and formed to fit properly. I also had 1/4" of softer foam applied before being covered. Quite a comfortable and stable ride now.
1 - 14 of 14 Posts
