1 - 3 of 3 Posts
I just purchased a 1992 with drum brakes, the brakes are questionable at best. How difficult is it to convert to later model disc front brake?
Just my opinion, but if you find the drum questionable you probably won't be tremendously impressed by the disc, either. I consider them pretty much apples-for-apples.
That said, in terms of parts you'll need the following:
Left lower fork leg (rights are all the same, earlier is better cuz it some still had drain plugs)
Caliper
Front wheel w/disc.
Master cylinder and brake hose.
Starter/kill switch from post-'01 TW (optional). If you use your existing switches the starter button will be pointing toward the ground due to the master cylinder and throttle cable locations. More of an inconvenience than it is a complete nuisance, but worth doing.
You'll need to splice the plugs from your early model brake switch onto the master cylinder brake switch because the later switches are a larger diameter.
I gotta agree with that, it's not worth the effort. I've had TW's with both, and the disc doesn't stop any better than the drum.
1 - 3 of 3 Posts
