I did some searching before posting so hopefully this hasn't been covered at length already...
In the "how to change your own oil" post there is a gallon container of what appears to be automotive engine oil. From what I've read there is some disagreement as to whether car oil is appropriate for a motorcycle. For the last year I have been using HP4S honda synthetic motorcycle oil (I'm not sure if that oil is even the best for a wet clutch). It's pretty expensive but considering the bike only requires one quart or so for an oil change I can justify the added cost. I recently purchased a second bike (dr350se) also air-cooled with a wet clutch. With the two bikes I will be needing to buy larger quantities of oil now and I change my oil pretty frequently.
Okay so after all that here is the question: Is there a motorcycle specific oil that comes in a gallon container that is also appropriate for the TW's and DR's clutch set up? or do I need to start buying the quarts by the case? Any advise is greatly appreciated. Thanks!
