They weren't against them.....
They were just useless ..
A waste of money..,
Something else to get in the way or broken
A waste of money..,
everyone does it's in the cdi boxYou have a rev limiter?
Oh I'm exaggerating a good bit. My last post about it wasn't bad, I have seen some other posts (probably the one workingman was referring to) where some folks just assertively shared their dislike and lack of need for tachometers on a 200cc motorcycle.I don’t understand, why were members having a problem with the tach subject?
At idle I’m at about 1000-1200 depending on my screw adjustment, and yes it holds very steady and is very responsive. It revs up to 9500. As far as the light goes, it does not turn off but it does dim 30% which I put on a toggle switch.Can the light be turned off ? Does it hold perfectly steady at idle, and what rpms does it show?
I wish you had messed with Brian telling him it’s gear drive mechanical which wasn’t that hard after adding the blower lolThank you! It’s electrical.
The light can be turned off if you add another switch to the mix. There's a 'black-out' version you can't see the display if the light is out too. However, it's my experience that lights go out and that would make the tach worthless in the black-out version. I want your version and I don't plan to hook up the light. I don't ride at night and even if I did, I wouldn't need a tach while doing so.At idle I’m at about 1000-1200 depending on my screw adjustment, and yes it holds very steady and is very responsive. It revs up to 9500. As far as the light goes, it does not turn off but it does dim 30% which I put on a toggle switch.
On the stock xt350 tach 11k rpm is at 180 degrees, so I’m not sure how that would work. Possibly find one that is at the same angle and reading and it could possibly work.I notice the swing arc from zero to 9K rpm is 180 degrees. I wonder if this tach could be gutted and fit into a XT350 tach body? The lights would work; turn signal, high beam and neutral.
