1 - 9 of 9 Posts
Thank you. 14mm will not work? Also, what are the M5 screws for? Thanks
It's been a few years since I made the switch to the socket head screws, but I believe 14 mm will work, the one that holds the bracket for the idle adjustment cable may be a bit longer.
The m5 screws are for the cover to the coaster circuit diaphragm.
jb
I used m4 14 without problems, but I recommend SS so they don't rust.
Never had any sign of rust on the screws I originally used....that was all Lowe's had in stock at the time.
Not long after, I changed to SS screws........ ;)
jb
1 - 9 of 9 Posts
