I have a good used stator assembly pt. # 2YG-81410-MO-00 and a good used Pulser coil pt. # 2YG-85580-MO-00 for sale.
Here is the deal: I pulled them from my 1997 TW200, as I had myself convinced that they were bad! WRONG!! I wish I had found this forum FIRST before thinking I knew everything! It was my Carb, & not the coils after all.
So here is the deal: First go to this post on this forum http://tw200forum.com/index.php?/to...++coil++resistance++__fromsearch__1#entry3643
There you will see all you need to know about this part(s) & proceedures! Pay close attention to the part where he talks about breaking off one of the screws! The same thing happend to me, except it was the screw that held the wire protector plate! These screws are real tricky to remove, I recomend a good #3 philips that you can put a wrench onto, to help turn the screw while exerting maximum downward pressure!
To sum it up, these parts have around 900 miles on them! I bought the bike with 888 miles on it from a one owner guy that did not beat it, its worst sin is that he stopped rideing it & let it sit for years!!
If you need these parts, let me know, I will send them to you, you install them on your bike, and if you are happy with the way they work, you send me $125.00! I will even make a traceing of the side cover gasket if you want to take a stab at cutting out your own.
Let's be fair, only respond if you actually need these parts, I'm sure someone does. So let me know if that's you.
M.
Ironic timing, I am in need of both of those exact parts. I have gone through my whole sytem trying to diagnose a problem with my bike. After weeks of frustration I took it in and found out that I need the stator and pulser coil replaced along with a crank case cover. I would really like to pick those up from you seeing as the shop here in Hawaii is not cheap. Please let me know as I am anxious to get it running again.
thanks!
Sorry, It's sold. I hope you can find one, new they ain't cheap!
I'll keep my fingers crossed for you, There's bound to be one out there somewhere. m.
