1 - 13 of 13 Posts
Front rack for the TW 200 Sits above the head light. So when you put gear on it, it does not block the Head light.
Made in the U.S.A.
Made from 1/8th inch aluminum. Comes with no coatings. No paint, powder coat, or anodizing. They will not rust. If you want it a different color, thats up to you.
Comes with 1/4-20 Stainless Steel button head bolts, and washers, Nylock nuts.
Bolts on to the triple clamps using factory bolts.
Has 1 1/8 x 3/16 slots for straps or bungee cord hooks. An a few holes for cordage or hook points, or mounting other accessories ( Like LED pods and the like )
20 pounds or less weight limit. ( It will hold and carry more than that. But I highly recommend that you DO NOT. I put 40 pounds on it for testing. I twas dangerous and Scary. Very unstable. You are going to notice 20 pounds enough. )
$70.00 Shipped in the U.S.A.
To order. Send a email to [email protected]
I will send a PayPal invoice to you.
204762
Installation:
First support the bike
204763
Then loosen and remove the Triple clamp bolts on both sides.
204764
Then slide one side support piece over the turn signal with the tabs pointing toward the headlight.
204765
Then install the top triple clamp bolt finger tight only.
204766
Then the bottom 2 triple clam bolts can be installed.
204767
Make sure your fork tube is in the right place.
204768
Then tighten the bottom 2 triple clamp bolts then the top 1 triple clamp bolt.
And repeat for the other side. Should look like this.
204769
Now for the top plate:
Lay the top plate on the side supports, align the 3 holes on one side insert screws from the top, Put the washers and nylock nuts on from the bottom loosely.
Do this for both sides.
204770
Then tighten them all up.
204771
Check everything again to make sure you got everything tight.
You're all done.
Installation:
You're all done.
Very nice!
I suspect that when I am finally allowed a trip to California to pick up my VanVan, there is a good chance I will sell the TW.
If not, I will buy your lovely front rack and the matching rear rack. Get busy.
It will be kinda hard to beat what's already out there for rear racks, But I will see what I can do.
I suspect that you will find s way to do a medium, king sized rear rack, and panier, that will suit me.
Or is it time to start on the VanVan.
Ok. You got me thinking about it. I have some ideas to solve a couple issues I have with all rear racks. Stay tuned. And keep the TW.:cool:
Reactions: littletommy
Loghousenut did a fantastic job of twisting your arm/suggesting (haha) you build him a rear rack!! He wasn't going to take a no at all!!! LOL :LOL:
*and you gave in so easily... :ROFLMAO:
BTW sweet job on the rack bro!! (y)
Thank you. I guess I just needed to a little push to solve one of my concerns with building a rear rack.
Sent from my SM-N950U using Tapatalk
I'm in for a matching pair, if/when. :cool:
Reactions: mekdad
Nice rack .
not something I normally say to a guy.
I am considering this rack for my EXPLORER 3 project
I would like this rack much more if smaller mounting plates mounted to the
Triple tree and then the rack mounted to said mounting plates .
It would make it much easier to take it off and just put it on when needed.
Would you consider making a 2.0 version of this rack for people that
May not need the rack full time ?
1 - 13 of 13 Posts
