1 - 20 of 31 Posts
I've been waiting to get into a TW until I found one that was cheap enough, close enough, and running enough that I could justify it while I work on my street legal BW project. That glorious day came last week when I saw that LuvNot had posted her bikes Frank ('99) and Charolette ('96) for sale with a ton of extra parts for $1500.
The wife gave me permission (on our anniversary no less) and I set up the deal with LuvNot. We met up halfway on Saturday and I drove the 2 hours back running through all the options in my head. Once I got back home and had a chance to really look over the bikes and all the parts I decided Frank (short for Frankenstein) was probably modded past the point of economically returning to stock, and that Charolette was almost completely stock (except for the handlebars and maybe one or two other things).
Frank kicked right over and was taken around the block while Charolette and the parts were loaded into the shed. I spent the first couple of hours troubleshooting Charolette--the float was stuck and the inlet had to be cleaned out but once fuel was flowing I got her to run for about 20 seconds holding the throttle partially open.
Since then I have turned my attention to Frank; I ended up robbing the plastics and rear turn signal off of Charolette, making a new mount for and reinstalling the clear Clark XT350 tank, and disassembling the cowl to paint it white and reinstalled it with new stainless hardware. I really like the way he is turning out.
Oddly the kill switch doesn't do a thing and the horn doesn't work. Could those two things be related? I ordered a new battery to help with troubleshooting on the bikes, which should get here on Thursday. Other than those two things, I will be getting the seat cover modified to fit the tank wrinkle-free. Though, it is tempting to source the parts for a front disk brake and use all of the TTR parts I have to convert him into a high compression 225cc 6 speed...
Overall I am really happy with deal. I love having kickers on both bikes and its nice to have a clean stocker and one to farkle. Sadly, in the long-term I will almost certainly have to let one of them go (and maybe both once the BW is finished, which is quite a ways off), but hopefully I can get a few good rides in with my wife and perhaps one solo weekend trip before that day comes!
Nice. It looks like a fun project for you.
For the horn, try hooking up the horn unit to the other bike to see if it's the horn or the power supply. If it's the horn, try turning the adjustment screw in or out.
If it's not getting power, you may need to take apart the switch and clean the contacts. On the '87 I'm working on, it was a combination of both these things.
It may be oxidized contacts on the kill switch, too. Personally, I've trained myself not to rely on the kill switch and just use the key. That way, there's no chance of running the battery down by leaving the key on.
Wondered what happened to LuvNot. She came to the San Rafael Group Ride in Utah this spring then kind of disappeared.
Always sad to lose track of a respected forum member but at least her bikes will continue on here courtesy of YBW.
Frank sure is looking better in white.
That’s a smokin deal. Glad that set stayed in the family so to speak. Good advice from imlost on the horn I was also lucky enough to have a second bike to help with testing. I finally had to spray mine generously with WD40 and bang on it something inside it must have been corroded and stuck. Works as weak as ever now. Killswitch on my 01 has also never worked since I’ve owned, I just use the key and they don’t inspect older bikes that closely here in WI for license/title. Cheers
Thanks everyone, and I agree--the white is looking quite good! I didn't have a chance to do much more than pop the old battery in to try the horn again. All I could hear was some type of click when I pushed the button down, I will have to try unsticking it when the new battery gets here.
I did however get the title transferred/registration/insurance and took Frank out on a few mile jaunt to get gas and get a better feel for what might need done. Overall things are good but it seems almost everything needs "dialed in", which is essentially what LuvNot told me. I'm worried these street tires are going to have me spoiled by the time I get the knobbies back on.
The inspection runs out at the end of this month, so I have a couple of weeks to get the horn fixed. I usually don't use the kill switch either but I figure its good to have in the event of a stuck throttle or something like that. Here is another pic from today, it seems like the gas tank matches better when its full?
If it's clicking or making a "ka-tunk" sound, it's getting power and your switch is working. It sounds like it just needs adjusting. Just back-off / turn-in the little phillips screw on the front.
Remember, if you need to kill it in an emergency, you can always pull the plug wire, provided you wiped-out with the right side of the bike - up. Be ready to get shocked and to hear a backfire, and remember - Your shorts can always be cleaned.
It looks pretty sweet. I think I'd leave those tires on Frank and have a nice pavement bike, and make Charlotte in to the boonie-crasher. If you do that, put the rack on Charlotte. She needs a big rack.
Hmmm its more of a simple "click" that sounds like its coming from under the seat, not the horn, so maybe a relay or something? I don't know what I punch into my phone but I just realized it autocorrects to Charolette instead of Charlotte, maybe someone could do me a solid and change the title for me
I've never really understood the attraction of the supermoto style bikes, I will need to do some reading.
Talking about big racks, I have a Tinman Tim rack that was included with the bikes.
Still here, just not as active. Little under the weather and busy with doctor stuff as well as house stuff. Hopefully this break will be short. Just really have to get things taken care of so I can move forward with plans!
I'm really glad to see Frank and Charlotte are in great hands! It's exciting to see them up and running and being used as intended. I look forward to seeing the end results when he's finished :D
Good that you are still involved in the forum, LoveNot!
Discussion Starter #10
So the battery got in and its definitely something under the right side cover that makes a single click when I press the horn button. I found the starter doesn't work either. I took the right side controls apart and the contacts looked good, so I'm assuming its something to do with the wiring of the whole control? Any ideas?
Discussion Starter #11
Well it was this relay clicking. Sure enough I messed with the adjustment screw on the horn and it started honking. I started tracing the wires from the right controls to the very well made wiring box LuvNot built behind the aftermarket headlight/cowl.
The connections looked fine and one blinker started to not light up so I got scared and buttoned everything back up. The good news is you can apparently still pass inspection without a kill switch in VA as well! I snapped a picture of the tank mount while I was looking at things. We just welded (gasp!) a piece of flat stock to the underside of the old mount because i wanted the tank to rest as flat as possible. Then drilled/tapped the hole.
Discussion Starter #12
I spent some time last evening getting the Tinman Tim rack back on Frank. I believe LuvNot had to modify it to fit a messed up passenger peg mount, but after I got that reversed it slipped right on, so she must have replaced the mount at some point.
Overall I like it much better than the Cyclerack. It fits amazingly well around everything from the turn signals to the plastics, and though the finish on the welds aren't quite as clean, it has to be at least as strong if not stronger. I don't even have the bolts in the peg mounts and its already rock solid. Right now the plan is to weld Rotopax mounts to the panniers (the 2 gal. would fit perfectly) and then put a dry bag on the back. I may even get it powedercoated.
The only thing I don't like is that since it uses the passenger peg mounts, you obviously don't have provisions for pegs, but I am just going to weld new mounts on the brace forward of the old mounts. I also got the mount for the tool tube modified to be used in conjunction with the new rack. Here are some before and after pics.
Discussion Starter #14
I used some brake fluid today to strip the paint from Frank's old black and copper plastics. It worked really well and now Charlotte is back together and looking good. I need a few odds and ends and then I can really start troubleshooting.
The good news is all of the electrical works, and I got her to idle a few times for maybe 5 seconds or so, and then she refused to idle but would run for 10+ seconds with the throttle applied (and would rev pretty high). Sound like anything you guys have encountered before?
Otherwise she sounded good. I'm thinking about pulling Frank's carb and trying again just to rule that out.
Charlotte looks pretty hot with a makeover. :icon_thumbright:
You might try Frank's CDI on Charlotte, just to rule that out. It's way quicker to switch the CDI than the carb.
Discussion Starter #16
Carb it is! I put Frank's on her and she started right up. She sounds great and the only thing I can tell right now is that the clutch doesn't seem to release all the way. I guess it could be the plates sticking from sitting or a cable adjustment, but it rides great!
I put her carb on Frank just for giggles and of course he won't start, so now I need to make the replace carb/rebuild the carb myself/pay someone to rebuild it choice. I'm really inclined to choose the last option as that has seemed to work the best previously. Do we have a forum member that does that?
Discussion Starter #17
I ended up buying a working used carb still attached to the bike. It ended up being by far the most cost effective way to solve the issue (especially given all of the other parts I need off of the bike).
Apparently it was used to fetch the mail at the end of a 2.5 mile driveway of a 300 + acre property with a 10,000 sq ft + house. Then the guy I bought it from rode the heck out of it. I dare say it's the best running of the 3, and it definitely has the least miles.
LOL. Careful there my friend or you'll end up with a dozen motorcycles just like I did LOL! :D
Discussion Starter #19
No joke! I ended up putting Charlotte's original plastics back on her. I have decided to use your naming method and call the new bike Rick (I bought him in Fredricksberg, and there are already too many Fred's on the forum). He has a Chinese clone carb and a battery coming to get him running again, then the spare tires you provided to get him back on the trail!
I won’t hear of it. You can’t name a bike Rick with a Chinese Carb. :mad::evil6:
1 - 20 of 31 Posts
