I've been digging around the web trying to find some info on adding more preload to the stock TW front springs.
I'm over 6' and right around 250#. I want to firm the ride up front and rear, but the spring manufacturers I'm used to using don't
make springs for the TW (Race Tech, Factory Connection, Eibach).
Has anyone made longer spacers for their forks, and did it help the ride?
Has anyone found a rear shock that will bolt up to the TW that is adjustable (preload, compression, rebound, etc)? I've seen a couple of threads about
using a Blaster shock, but that looks more inolved that I want to get, and it raises the back end more than I'd like. I don't mind some increaed
ride height at all, just not that much.
I had a set of Enzo sub tanks on my last bike that I'm kicking myself for not keeping...
Has anyone made a set of sub tanks? The one thing that I'm stuck on is the valve that regulates the air flow to the tank.
