So, working on my fork retrofit can't seem to build up pressure in the front brake. I can pump fluid through the hose when I crack the bleed screw. Only think I can think of is piston is not popping out. The pads were a very real PIA to get back into the RT180 caliper with the clips; need a second pair of hands.
any ideas out there. Once again I'm using a RT180 caliper since I'm running 97 rt180 fork legs.
thanks
thanks
