1 - 4 of 4 Posts
I have two Yamahas and I have noticed that the shifters are sloppy no matter how you tighten them. This is what I did to resolve the issue. I removed the shifter and drilled a hole with a 9/64 drill bit on the bottom side. I placed the hole not dead center but a little towards the outside edge of the shifter. I then used a 8-32 (29D) tap on the shifter. I then placed a 8-32 set screw in the shifter, just enough to start the threads. I now installed the shifter and tightened the mounting bolt. I then tightened the set screw. I used a little locktight on the set screws. I did both bikes and this modification was well worth it. I can feel neutral and each gear much better now.
What I did was to remove the bolt from the shifter, clamp the shifter in a vice so the two halves were clamped together, then took a hacksaw and cut down the parting line. When I re-installed the shifter and tightened the bolt it clamped the shaft much tighter.
So the shifter is loose on the spline? Hmm I'm going to have to take a look at mine. Thanks for pointing this out.
1 - 4 of 4 Posts
