Manual says to do this every 10,000 miles. Is this job something I can tackle myself.
G'day, Steve.
I had to replace my 93's at around 10000ks. I did it myself, but it is a bit of a PITA.
The standard bearings are the 'push-bike' type, which means lots of bearings between an upper and lower race.
If you have the provisions to get the front wheel off the ground, and take the forks out, I would say do it yourself.
Here in Australia, labor at bike shops is often $80 an hour, so it's certainly worth doing yourself!
Ideally, I would replace them with 'all balls' bearings as they are sealed tapered bearings (much better).
Two good points! Use marine grease as the stock seals don't really seal out water very well. We are finding malternative sources of many parts that save a lot of money over Yamaha prices. It is almost impossible to R&R the steering stem without losing a ball bearing or two so the lower priced source is a good thing.I also only use marine water proof grease
I laughed last time the balls were like $5 each on the parts fiche
Mcmaster sold me a 100 for I think $6
