1 - 2 of 2 Posts
I first read through the existing posts but could not see anyone referring to this.
When i cut the end off my grips, the open end of the bar was filled with soft metal.
Not completely to the top , there is some space left where you could pry about with a screwdriver.
I try to drilled a hole in it in order to put a screw in and to pull it out.
But i found that this 'metal' melted insert is more than a few centimers deep into the bar.
Is it for balancing?
I need to drill a hole for fit the expanding bolt in for my hand guards.
Just want to now what it is before I continue.
It is possible it is for the same use as bar end weights. Helps to curb vibration in the handlebars.
1 - 2 of 2 Posts
