1 - 14 of 14 Posts
I would like a set of minimalist hand lever savers. No need, at this time, for plastic wind deflectors, just the metal bar to protect the levers from braking. I suppose it would be preferable to have the possibility of adding the plastic later if I found it helpful. Suggestions?
Thanks, Will
I like the looks of the Zeta's that Holdon posted - and the fact that no modifications are required.
However, the Tusk D-Flex that Rhodetrip mentions are cheaper. I have 3 versions on my 3 bikes. One with just the aluminum bar, one with the additional standard plastic handguards, and one with the standard plastic handguards and the even wider spoiler that goes over them. I have to do a little bending and add a couple washers to get the D-flex to fit but I keep buying them.
Can anyone tell my the reason some of these bars are bent (wavy) towards the outer end as in Holdnon's picture ?
My guess is that it may alleviate clearance issues between the end of the lever and the guard. On other ones, I have had to grind off a bit of the end of the lever to get them to fit. Rubber side down, Dave
Thats correct it gives more clearance for your levers and also more room for your hand while wearing larger gloves.
The zeta website states that the bend is for more control
Twisted Throttle LTD is the US distributor for the original Bark Busters (I've been using them since the mid 80's) You can buy pieces to suit your fancy. The Bark Buster website has a fitment PDF listing choices for the TW200. I didn't compare prices to the other suggestions, but these are the originals. The name became generic over time, like Kleenex. I can't speak for any other brand, because I haven't used them, but you can smack the tar out of Bark Busters. Nail a tree and you will still have fingers. Beware of cheap ones. They are sort of like seat belts on equipment without ROPS...more of a hazard than a safety item. If you smack hard on a cheap guard, you may well have a blade coming at your fingers.
But without the plastic "wind" deflectors, how do you keep the cholla spines out of your fingers. Maybe you have wider trails or less fearsome vegetation. Cheers and my suggestion is go for the package. Tom
Cause the D*** weather man froze our Cholla's off:(
It only takes one incident with a " Teddy Bear " cholla and you will respect them for the rest of your life!
1 - 14 of 14 Posts
