1 - 4 of 4 Posts
Having lots of trouble starting my 2001 (electric start). When I check for spark, I get only a single spark when I first press the starter, then no spark as I keep it pressed for however long (a few seconds), then a spark again when I let go of the starter. On the rare occasion that it does start (likely due to the first sparking catching, it seems to run fine. Most likely a problem in the electrical system, but I have no clue what it is (this is my first bike).
Any help/suggestions would be greatly appreciated.
I forgot to mention the spark plug is brand new, and the old one does the same.
I have this same "problem" but I have learned to live with it. Last summer, I had to replace my stator winding and upon replacing it, I noticed the exact same thing as you mention; no real spark until you release the starter button.
trust me...it IS sparking while you're cranking. You could hook up a timing light or some other sort of "spark checker" to verify this.
The CDI makes a very powerful spark that may not be visible under normal light. Try it in a darkened garage if you can, you'll see the spark is there.
Here is what I do to make starting so much easier.
(Assuming a COLD engine)
- Turn fuel petcock ON.
- Pull out choke to about 80%
- Crank for about one second then stop
- "Blip" starter button quickly, mine starts immediately.
I've found that "blipping" the starter button seems to work better than cranking non-stop...don't know why that is. When I say "blip" I mean to just touch the starter button momentarily...for a fraction of a second so that it just gives the engine a slight crank.
Now I don't know if this spark problem started when I replaced the stator or if it was present since day one. Mine has always been a bit tricky to start because she is STOCK - no mods - and is therefore lean. But since switching to this new method of "blipping" the starter, she has been VERY reliable and quite easy to start, even when hot!
Give it a try.
I have this same "problem" but I have learned to live with it....
TW_in_BC,
I was hoping you had solved this anomaly.
Mine does the same, but did not when I first acquired the TW. I don't remember when the problem first started. I've done minor carb mods but have not done any changes to the electrical/charging circuits.
I now use your starter "blip" method too.
jb
1 - 4 of 4 Posts
