1 - 16 of 16 Posts
Thought I'd share with you guys my recent experience porting the head on my 225. I originally set out to fix the infamous base gasket oil leak due to the unevenly machined engine halves, but noticed that the passages could use a better finish and decided to go a step further.
Nevermind the carbon deposits (I am running rich and with a overfilled crankcase to keep the clutch temp down), a small step is visible in the passage past the valve seat. The intake valve is done the same way. Ideally these must be evened out at the factory, but it makes no sense for them to invest more time into a cheap product like the TW and they leave them like that, as it affects performance only marginally. However, being somewhat a perfectionist, I just could not tolerate it.
Another issue I discovered is the sharp bend in the exhaust path at the point where the exhaust manifold attaches to the head. The path is straight, but the manifold attaches at an angle to clear the frame. Not good for flow efficiency (I will get into that later). My solution was to dremel the passage to enlarge it slightly and introduce a curve.
Factory design:
My solution:
Discussion Starter #2
So, the main factor at play here is turbulence, which is almost never good. Steps and abrupt changes in passage direction create turbulence and turbulence reduces max flow capacity, which limits the efficiency and power of the engine.
I used my dremel to grind down the steps below the valve seats to an even surface. They are visible initially, but as you work on them you will need to use your fingers to feel if there is any unwanted material left
Another area where i discovered a step is where the carb adapter bolts on to the intake side:
Run your finger trough there and you may find that the diameters of the adapter and the passage are slightly different or misaligned. Make a note of where the step is, take the adapter off and grind it down. Be careful not to overdo it, lots of repeated bolting back, checking and taking off will be involved for a proper job.
Finally, there is huge step where the expahust manifold attaches to the head. You can see the difference in the diameters of the seal and the passage here:
THIS IS A DELIBERATE DESIGN FEATURE and you should avoid removing too much of this step. There is a process called scavenging, where the intake valve opens slightly before the exhaust valve closes and some of the intake charge is sucked into the exhaust to ensure the cylinder is completely free of the exhaust gas. This step prevents the exaust from getting back onto the cylinder.
I had to take some of it off to introduce a curve into the exhaust path, and also due to the reason that i have a 225cc, but you should try to keep at least some of this step:
The photos I am posting are mostly in-process and not of the final state, in case you are wondering if that's the way the final result looks :) I had to rush when assembling back together, as I had a bike trip with my pals coming up and did not take many photos in the final stages.
So this is the in-process photo of me making the passage curved.
And this is the passge in the finished state. Initially i took too much material off the exhaust step and could not curve it as much as i wanted to due to the fear of grinding through the wall. Though it is pretty easy to estimte how much material is left, as both sides are visible.
Finally, I used valve lapping paste on valves and seats:
The left (exhaust) valve has been lapped, the right (intake) has not. I used a minimal amount of regular (not diamond) paste and 10 back-forth movements by hand in each quarter (turned valve 90 degrees after 10 short back-forth movements)
Here are the valves. Again, the exhaust has been worked on. You may notice the intake valve seat has some small scratches at 1 o'clock. The paste has removed those right off (me happy:) I was very worried about damaging the seats and have not rised removing the carbon from the areas close to the seats.
Overall the project took about 3 weeks of evening work, but that's a very rough estimate.
I used steel bits to work on aluminium, stone to grind steel and rubber polisher for the finish. One word on the finish: there is a false rumour that you need to have mirror-like finish on the walls of the passges for minimal tubulence. Mirror-like finish does reduce turbulence, but it is detrimental for the intake passage, as some turbulence is needed to mix the petroleum with the air. As for the exhaust passage, the shape of it is much more important than the surface. The mirror finish accounts for no more than 1-2 percent of the peak power. If you the necessary tools to do it, it will not hurt, but there is no reason to be overly preoccuppied by it.
The most noticeable effects on the performance for me are smoother throttle respose (subjective) and, for some reason, reduced fuel consumption when I don't push the bike (I measure how much mileage i get out of the fuel i put in). Before I would never get below 3.4 liters per 100 kms, but since the mod I was able to get 3.1 one or two times.
I have not noticed any power gains and I have no accurate way to measure it.
Hope you guys find this interesing and if you have any questions, I will be happy to explain
I have looked at the exhaust port on several TW heads and the exhaust port compared to the gasket were all different sizes. It appeared to be flashing left over the casting procedure partially ground out by hand and probably by many different people, hence the wide variation in port size.
As I felt with my finger going from the ex. valve to the outside, it was as if there was a wall where the "flashing" was and it seemed to be the most restrictive point, the place that impeded the flow of exhaust gases the most.
Your explanation of the huge step at the exhaust port preventing a reverse flow of gases is very interesting. I have never heard that before. Even with camshafts designed with huge amounts of valve overlap (both valves being open at the same time to promote scavenging) we always matched the port size to the header trying to create the least restrictive path, but then this was on big V-8's in my hot rodding days (daze?) from my misspent youth.
To me it seems the valve overlap on the TW camshaft is minimal. From what I have read one never really knows if the porting is doing any good without a flow bench. With that in mind I bought a couple of really cheap TW heads off ebay and did my own porting.
I installed this head on my TW with the only previous mod being a 70mm Wiseco piston. The exhaust note has a definite pop that is sharper than stock and it seems to run better than with the stock head but then that could be "placebo" and/or wishful thinking. I wish I had access to a dyno.........
Discussion Starter #11
I found a description of this by an engineer who was involved in designing engines for a major car manufacturer. My logic tells me that matching the port size to manifold size would definitely produce better results on the flow bench. But scavenging-wise, it is a slightly different matter, wherein the benefits of better flow could be offset by a decrease in mixture quality.
As you correctly pointed out it is quite hard to be objective about any power gains without doing a dyno run. From what I know changes in power of less than 10% are not noticeable.
The issue with our bikes is also that the CDI decreases timing advance after 5K RPM (or around there, don't remember where exactly) and any increase in port size would push the peak of the power and torque curves higher in the RPM range. So porting is risky in the sense that one might end up losing low- and mid-range power with a head optimized for peak flow at 7K RPM only to have the CDI limit it at 5K...
Elime did you do different kind of porting on each of the heads you bought? Funny but I caught myself thinking that my exhaust became quieter after the mod:D It's as if I hear more out of my drilled airbox now than out of the muffler...
I treated both heads the same but the first head was very cheap, something like $15 total, and it has some stripped out bolt holes, the most critical ones being by the exhaust pipe. Going the cheap and easy route, I was able to screw a stud into the bolt hole and catch 2 or 3 threads at the bottom and then glued them in place with epoxy that was supposedly good to 550 F. When it came time to pick a head to try out I went with the other head -- I didn't have confidence in the epoxy that close to the exhaust.
What I did was smooth out the step next to the valve seat on both the intake and exhaust valve. After that I "hogged out" the exhaust port where it goes into the exhaust pipe as seen before.
I previously had an after market camshaft and CDI installed on this TW. I went back to stock on both when I put this head on. The camshaft has greater duration and overlap and a noticeable loss of power at lower RPM and a noticeable gain in the upper RPM. I am not sure I like it but it is different. I don't have the specs for the stock cam and the aftermarket specs are at .040". I am used to either 0" or .050" but you can see the difference in the lobe profiles in the picture. You can calculate the overlap from these specs.
As for CDI, I bought a Igni Tech CDI with adjustable timing, at least they say it is adjustable. I have played with mine and it seems to make a difference but here again, if I only had a dyno.
Have you heard of this company? If yes, what have you heard. They seem legit.
www.ignitech.cz
Here is a screen shot of the program used to change the timing. The red line is one of the advance curves I made, the blue line is the stock curve I tried to copy from the shop manual.
Lots of fun things to experiment with on a TW. The sound it makes is different than before. A sharper, slightly louder sound. I guess I could put the stock head back on and find out for sure if it is the head, but honestly, that is way to much trouble. Tony
Discussion Starter #14
Yes, the TW is a great toy for the us gearheads :)
Tony, I have heard of ignitech and they are legit. I don't know anyone personally who has their CDI on their bike, but on the local forum there are many people who have their products. Especially the Transalp owners - they consider it a must to adjust the timing, apparently the factory setup is for poor quality gas and there is lots of room for advance. I think that a way to check if your unit works would be to completely remove any advance and try to ride the bike. The difference would definitely be noticeable.
Speaking of gas, I see that you have pushed your curve by 5 degrees. What was your experience with different octane fuels? Do you run 95 or have you tried lower?
I'm now considering this CDI for myself :)
In California the easily obtainable gas is 87, 89, and 91 (or is it 92?) octane. I use the 91 (92?) most of the time. Most people use the 87. As far a performance goes I can't tell the difference but I am using a little higher compression piston, it is only 50 cents per gallon more, I am only buying about one gallon at a time and it makes me feel better so I use it.
Next time I install the CDI I will take you advice and set the "B" curve to all zeros and see how it does. I imagine it will run OK but won't have any power.
1 - 16 of 16 Posts
