Help please I'm tearing my hair out. I'm in the UK and bought a (US Import) project 91 Tw from the internet as a non runner last year. I knew the bike had bits missing + broken but when it was delivered it was also missing the CDI and the pilot jet mounting was broken on the carb body.
I gritted my teeth and bought an Ignitech CDI and chinese BW Mikuni. Although the bike starts fine it wont rev cleanly or pull when you try to ride it. If you slowly open the throttle it usually revs but any quick action makes the bike pop and splutter. The plug is very sooty but this is maybe because its not got hot enough to burn off. I've set the valves normal and slightly loose no difference, new plug, new fuel, with and without air filter, sprayed around the carb mount for leaks, dropped the needle, checked for fuel flow and vacuum at the filler cap. Tried the carb with and without the vacuum vent blocked. Tried with the crankcase breather pipe off. I've checked the carb several times and put fine wire and sprayed through all the holes. Float level looks fine I tried it normal and slightly lower.
Any ideas would be appreciated, i don't want to be beaten by it but am getting close.
