Anyone change the gauge clusters out to an aftermarket single speedometer / gauge? I'm wondering how hard getting all the wires matched up is gonna be?
About this hard -http://tw200forum.com/forum/technical-help/39681-need-help-speedo-dash-wiring-led-everything.html
Having said that, the OP seemed to get it all sorted soon enough – lol …….
Give him a PM and I'm sure you'll save yourself a lot of grief ...... ;)
if yours has separate earth/ground black wires you will be ok, if not you will have an issue with the neutral light staying on.
they are pretty simple to wire up, there will be a wiring diagram with the speedo, if you have a battery lying around you can test out which coloured wire and ground go to each light.
here are the TW wires
neutral - sky blue - (this is a ground)
light brown - 12v +
black - ground -
brown/ white - indicators supply
dark brown - indicator left
dark green - indicator right
the yellow from the head light has a double connector on so your high beam wire goes there.
