I've been thinking of the easiest way (as well as least expensive way) to transport my TW with my Suburban (no problem with a 2" hitch bar) or with my Saturn Vue (small SUV - problem is a 1 1/4" hitch bar).
Choices are:
1.) A small trailer seems easy, one can be purchased for as little as $145 from Harbor Freight with their 20% off discount coupons. There would have to be added a 3/4"thick plywood floor extending 1' each for and aft longer than the trailer's 48" length, and probably a front wheel chock, and a ramp would need to be made or bought. This would fit either vehicle, is just another thing to have laying around when not in use but could be used to transport other "stuff" too.
2.) A hitch mounted bike rack to avoid the trailer. Most of these are rated for at least 400lbs if not more. Choices are aluminum or steel, solid all the way of their length or made of bolts every 6" or so between 2 side rails, with a solid ramp. These come standard with a 2" draw bar, will fit the Suburban with no problem, but it wouldn't fit on my Saturn.I can get an adapter that fits into the 1 1/4" receiver of the Saturn that the 2" draw bar of the rack would then fit into, but this would extend the whole thing out another 12-18", which puts more weight on the back because of the leverage and more leverage on the receiver.
One question I have is how stable are these things in the receiver - how much rocking side to side do you get with these at rest or on the road?
Do you just push or muscle the bike up onto the rack, as opposed to using the engine and clutch to power it up? How easy is it to roll up? And getting it off is just rolling it down trying to use the brake?
3.) I already have a small jetski trailer that could easily be modified with a central area of wood to support the bike and I would add a front wheel chock up front, and have to make/buy a ramp. This seems the cheapest and easiest and I could make the center bike support removable and leave the bunks in place for the ski when I need to use the trailer for that.
My real question is for those that have used these rear racks is on ease of use and how stable they are and, any suggestions for mounting on a 1 1/4" receiver. I don't know of any rack made that uses the smaller drawer bar but there might be a place where the bar could be bought separately and interchanged on the rack when and if I wanted to switch between vehicles.
Anybody have any suggestions or thoughts or ideas on all this?
Choices are:
