I've always used a funnel. If I had a drum of oil and had to pump the oil into something first, then the jug is the way to go.
Waitaholdit!!Usually someone in my pit crew does something like this. It really don't bother me all that much.
That's great information! Ingenious really. Repurpose a throwaway item and actually make it valuable.In the shop, I use a transmission funnel. Don't need a measuring jug if I just use a single quart bottle. If I'm using the bigger jug then I pour the oil into an empty 1-quart bottle I keep for such occasions. If I'm just putting in a dab of oil no measuring jug is needed there either.
Nothing fancy. If I have to add oil when out camping I reuse an old octane booster bottle and cut the bottom off to use as a funnel. It also fits nicely into the oil filler hole. Pop bottle mouth openings are too big and oil inevitably drips down the case thus using a bottle with a smaller mouth opening. This way I don't have to pack funnels from home.
I keep the bottle lid to minimize leaking oil all over the place and put a shop towel inside to soak up excess oil that hasn't dripped into the engine. Then use the shop towel with oil residue as a fire starter.
Those are great at the gas station if you have to get oil. No mess to go back into your gear.Paper throw away funnel ....... ezpz
Does your tranny funnel use they/them pronouns?At home I use a tranny funnel. I keep one of these on the bike for road use https://www.amazon.com/Nayciiy-Flexible-Draining-Foldable-Reusable/dp/B0BPS6634W/ref=sr_1_1_sspa?crid=WHB6P733NGCY&keywords=travel+oil+funnel&qid=1684971697&sprefix=travel+oil+funnel,aps,119&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFKMFJNS05DQzM5WVQmZW5jcnlwdGVkSWQ9QTAwODU5ODM1OVZBWEZTRVVLQjQmZW5jcnlwdGVkQWRJZD1BMDYwOTk5MzJGWk9NODBWTEUwODcmd2lkZ2V0TmFtZT1zcF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
