1 - 13 of 13 Posts
I will await those pictures. I have an idea how you did it. I know the JNS has threaded mounts on the sides. Just like to see yours. Would save a lot of money.
Discussion Starter #8 (Edited)
I slipped my mind a piece of aluminum bar stock into the OE headlight bracket. Seen here wrapped in black gorilla tape. Then tied some 14ga wire through holes I drilled in the edge of the bracket. All done with stuff I had on hand.
Nice, but doesn't the headlight's stated 150 watts significantly exceed the TW's nominal stator output?
I replaced mine with some led spot lights, took a little fab work and two of them come in at less watts than the stock headlight. I wired them to both come on, regardless of high or low beam because of how bright they are
1 - 13 of 13 Posts
