i miss my 04 tdub so much im looking at buying a 01 with 9800 miles this weekend, and im assuming its will be time to tear into it right away for reliability's sake?
thx
glassankles
thx
glassankles
thats good to hear, i will give it a test run and row it through all the gears.
could be fun to send it to Maxpower RPM's and see what kind bore and stroke he could come up with, lol
thx
thx
glassankles
other than variable reliability right off the production line, it's all about where and how you ride it..
if you climb hills in a 110 degree desert or something running nearly red line I'd be shocked if the thing lasted 5k Mi. heat kills, and so does running near red line. Put them together and it's doomed.
If you run it much easier, like just cruising 40-50 down the road like I do with maybe a little off road mixed in on a cool 60-75 degree day, it should easily get to the 30k mark I would think. maybe even 50 or 100?? who knows, but I know a TW that has seen solely on-road use running the engine no higher than 6k should be really easy on it and last quite a while.
I heard the optimal running temperature (Especially for off road) would be somewhere between 35-45 degrees. It should stay nice and cool from the air even as slow speeds, and you combined that with running the engine at it's happiest cruise speed (5k flat) it would probably last virtually forever.
Saginaw, Texas, to Saluda, North Carolina, 1028 miles in 19 hours last weekend in June. Fort Davis to Presidio to Terlingua to Fort Davis, 253 miles at high altitudes and 112*F last weekend in May. Currently 43,XXX miles on the odometer and the bike is finally starting to burn oil. TWs don't mind screaming their guts out in hot weather.
How about numb butt?Iron Butt?
Monkey butt?How about numb butt?Iron Butt?
