I've seen threads where folks had to do some mods for bigger Clark tanks. Now I've become aware that Clark has one specific to the TW. Any other mods (seat, mounts, etc.) required?
http://www.justgastanks.com/store/i...d=1334&zenid=34b9c206191c959762764015499a0d2dhow many gallons does the clark hold and what is the cost ?
sorry to read that. someone else on the forum did the same thing before. having the clear version, i could see that those channels were hollow. hopefully people can find the stories of those it happened to and not make the same mistake. someone suggested gas proof epoxy to the other person. maybe something like that could salvage the tank?Just Got my tank in today! Right front panel wont fit so not reading the info on this forum I decided to trim the mounting tab where the panel snaps into the tank. Not a good Idea! You wouldnt think the gas could get down to the mounting tab but just a little grinding with my dremmel tool and I had a leak! I waited close to 20 days to get this tank and now its useless!![]()
HDPE is pretty cool stuff - completely recyclable. There is no adhesive or caulk that will really stick to it or glue it (there is one very expensive product that purports to be PE glue, but it is a very weak bond). That said, as Kneehole said, it heat-bonds better than almost any other plastic, creating a finished repair that is as strong as the original piece. This is how one bonds one piece of HDPE pipe to another - heat both pipe ends, pull them together and let cool, and it's like it was a single piece. there are HDPE pipes 5 feet in diameter out there that were bonded exactly that way and they are still leakproof decades later. HFT sells a plastic welding tool to make repairs to HDPE, don't know how well it works though.It's not useless. You can repair it easily. Clarke (and other) plastic gas tanks are made out of high density polyethylene (HDPE). Empty the tank out and then using an air hose, blow the inside dry to remove all gasoline vapors. Using a propane torch, heat the tip of the dinner knife for 30 seconds or so, then lay it onto the area of the tank on both side of the hole. The hot knife will melt the outer layer of HDPE and as you work it around the hole, you can slowly close the void until hot melted plastic on both sides of the hole come together. As the knife cools, reheat and continue the process. Eventually you can get enough of the melted plastic over the hole so that when it cools off, it forms a solid repair. I have repaired three plastic gas tanks like this. In some cases, if the hole is too large, you can cut up a piece of Nalgene, or any other plastic container with the HDPE logo on the bottom, and melt it into the void. It's not pretty, but it works.
