1 - 4 of 4 Posts
Is the swingarm on a XT225 the same as the TW200? I have some mods I want to do and found one. Thanks for any info........
Nope. Ours are nearly a foot wide between between the axles, the offsets are entirely different, the XT's use a linkage shock etc.
I think the only things we share might be the snail adjusters and possibly the axle diameters, but the profiles are not similar enough to combine for an extended swingarm
Thanks, I did take a closer look at some pictures and saw the different shock linkage/setup. The one I saw advertised it as working for both. I'm going to need to modify one for a rear disc setup. I found a disc setup that looks like it will work, I'll need to cut off the drum brake slide locator and wanted to keep one swing arm as stock so I could go back if needed.
i have a very clean swing arm i'd sell you. what's a fair price?
1 - 4 of 4 Posts
