1 - 15 of 15 Posts
2021 TW200
Hello everyone first post. And since i haven't seen a conversion like this I just wanted to share and give some input to people going this route and pricing. I live in south jersey and where the sand is thick and i dont want to druve fast anymore so I am making a FATCAT TW200 or an FCTW200 andwanted to get rid of the pogo sticks for forks . There is not much else to say that has not already been said here except you will
need to trim 5mm of the bottom fork tube and make a 5 mm shim to hold the bearing dust cover bottom as the BVC kit is made for a Tri-Z 250 you will loose your speedometer so i installed a plate and Trail tech computer "I wanted an RPM gauge anyway" I will update when I start the rear is done, Any questions feel free to ask . Except why because I just don't know I have issues OK . Motor vehicle Automotive lighting Automotive tire Motorcycle Automotive design
Fuel tank Tire Automotive fuel system Wheel Vehicle
Fuel tank Automotive tire Automotive lighting Light Motor vehicle
Tire Wheel Vehicle Automotive tire Motor vehicle
Tire Wheel Bicycle tire Motor vehicle Crankset
Wheel Tire Motor vehicle Automotive tire Fuel tank
Motor vehicle Gas Automotive exterior Automotive design Auto part
Tire Wheel Motor vehicle Bicycle tire Automotive tire
1. BVC trike fat tire front tripple kit 850.00 on sale
2. Crf105 front shocks 700.00 new take offs cheaper used
3. Crf 150 to 250 brake conversion mount 100.00.
4 Front fork guards ebay 30.00 bolts from honda 20.00
5. Trail Tech voyger .150 ebay
6. Bvc 12 inch rim 175.00
7 . ITP rear rim not on yet 75.00
8 Atv back hub not on yet 175.00
9. Tri z tripple bout for tube bug bolt 60.00 ebay
10 New tires that i did not get yet 400.00
11. Crf250 caliper 25.00
12. Misc bolts 30.00
13. Front fender and rubber mounts 120.00
14. Front disk 25.00
15. Rear atv hub Bradley performance for TW 250.00
16. 2021 tw200 used 100 miles 4200.00
That is very nice.
Imagine it took a bit of effort researching and sourcing the needed parts that would play together w/o much additional modification. Hope it delivers sand performance good enough for your loose Jersey sugar sand.
Perhaps a wider foot for the side stand could be a valuable addition unless you're one of those who just dig a hole deep enough to support the bike.:cool:
2021 TW200
That is very nice.
Thanks , it was a lot of measuring almost wish I could have used the tripple that uses the crf250 forks as used parts are half price but I think it would have raised the front end to high
2021 TW200
Look good how does it rde on the road I bet the new forks are sweet.
Thanks
I Just finished yesterday I dont think I will do to much road till I get new tires the front that's on it now is about 12-15 years old off my old quad but I will keep you updated after I save up for tires
The stock TW just begs for a plusher front suspension. While there are upgrades for the OEM 6” travel forks one can also go route of longer and/ or more sophisticated forks. My TWs have both Tri-Z and TTR forks but imagine other’s options would work. Extra travel is very appreciated at times
Automotive tire Gas Snow Wood Auto part
1 - 15 of 15 Posts
