1 - 20 of 24 Posts
Hey Guys,
Just wanted to quickly introduce myself, I just purchased my first Bike and I've had my eye set on the TW for a while.
I'm an expat living abroad in Hong Kong and ever since I landed I noticed a lot of these "naked yamaha's with big fat tires" I thought they looked sexy right from the get go, after doing a bit of research I've found there is a real cult following for these bikes world wide, including HK but real big in Japan.
I finally took the time to get my Bike licenses here as i'm tired of running public transport - in HK owning a car is very expensive, mostly due to parking but you can park a bike for free.
I piked up a 2002 from the second HK owner, from what I can tell it was imported from Japan in 05, and it has 22k on it. It has a few mods including fenders ripped off, rear break light replaced and new exhaust (sounds good). I hope over the next 6 months i can tune the bike up a bit more to make her special.
I plan to put new tires on next week - Bridgestone 203/204 as the current bike has a mismatch front a rear. I've browsed the forum and for road use I hear these should be best bet, however slightly slippery in the rain? (please comment if you feel differently)
Next Mods:
- Remove all plastic
- Remove bulky TW emblems from gas tank and repaint
- Fix rear of the bike to move signals and break lights closer to the back of seat
- change rear suspension (potentially the blaster shock) I'm 6'4 so I think this would be a nice mod. (if anyone has a shock/kit they want to sell please PM me)
- Paint or replace handlebars as they are slightly worm. (not rusted but looking a bit corroded)
- replace or remove plastic boots from front forks (one is cracked)
Anyhow, Stay tuned and I look forward to participating in the forum over the next 6 months.
Nerk
By boardatwork at 2012-05-01
pm'd u back - with an address..
yes those 203/204 are prettty bad in the rain..
the knobblies I mentioned seem just as good or bad...
I think you might be able to get shinko here - but everywhere I went said the 203/204 werent here any more .. ( that may or may not be true )
nut as I said the knobblies are going ok..
I did want road tires actually an perhaps you can order on line if u cant get thru the local lingo
Dub,
Just wanted to say a quick thank you, you've been a bike help so far!
no worries! I'm motorbike mad!
since you wont have your bike for another 2 weeks then perhaps consider getting these shipped over..
has any one else used the battlewing's?
http://www.motorcycle-superstore.com/1/28/395/44669/ITEM/Bridgestone-Battle-Wing-BW502-F-Rear-Tire.aspx?SiteID=CSE_Nextag_44669&WT.mc_ID=80005&zmam=88421133&zmas=1&zmac=4&zmap=44669
the shinko's look good as well for street riding... I heard them mentioned a few times up here if you look for tire threads.
http://www.motorcycle-superstore.com/2/29/393/20396/ITEM/Shinko-705-Series-Dual-Sport-Front-Tire.aspx?SiteID=CSE_Nextag_20396&WT.mc_ID=80005&zmam=88421133&zmas=1&zmac=4&zmap=20396
or get you g/f to look on and see if they are locally - cos I asked a 2 or 3 places ( but not the yamaha dealer??) and could only get the TW34's - which as I have said do feel better than a worn out tw203/204 combo.. ( is that
http://ibike.com.hk/
yamaha dealer
http://www.ibike.com.hk//02_market/yamaha/07_web/index.htm
see if she can find you a set.
If she does let me know where! cheers!
I'll be on a beach in the Philippines for the next week and a half, not much will get done till I'm back. I'll let you know how my hunt goes!
Welcome to the TW forum.
So with my busy schedule I was able to finally pick up my TW200 yesterday.. It was located near the China Border in Yuen Long while i live on Hong Kong Island.. about a 1 hour drive. I had a few friends join to escourt me home... It was my first real ride on real roads - all is good and my baby sits in her new parking spot..
She ran well, a few minor things I noticed that makes me want to get it in for a tune up. After i parked her i could smell a bit of burning oil. I'm not sure if its because it sat for a few weeks with out being driven!? or should i be worried about something more serious?
I can sure relate to dubstep with the sloppy roads here in HK. I need to get some new rubbers on her ASAP!
probably advisable to keep an eye on the oil level for the first month - see what it is burning off..
how does the oil look in the inspection window? is it brand new oil?
as its HK I bet there's no service history in the TW price range
honestly for tires I think the TW302 are great for roads..
according to the Bridgestone site they are designed for road use and wet road use too..
so they are knobblie - but if you look at the knobbles there are way more than a "proper" off road tire.. so I think of them as road tires with extra sized tread
looking at your pipe I think off road isnt gonna happen.. so you can try shinko's if you can find them they *may* be better as 100% road tire... but honestly I feel pretty good with 302's on the streets,,, and on my Honda CRM250 I'm pretty aggressive on them..
Owen Motorcycle - ( 2398 1411 ) the corner of Nam Cheong Street and ferry street Sham Shui po - they will fit inside an hour.. if I remember it was around HK$ 1900 for front and back..
else try the Yam dealer for TW203/204? lemme know ho you get on
Thanks dub, its good to hear from you. I had a friend recommend a shop in quarry bay that will install the 203/204 combo for 2500 or 3K if I need tubes? It will take one day to order the tire so plan is to go monday.
Hearing 1900 installed on the 302 has we wondering - do you think the 203 should be the same price!?
I'm going to have the shop do a full inspection / fluid flush also. Start fresh on all fluids.
+1 on fluid change! you mean oil for sure but brake fluid?
I changed the brake fluid on "mine" - and it was amazing - cos the soft feel of the brakes was probably down to the fluid having lots of water in it!!!!
some people recommend a new chain when you get a bike as well - since you dont know how long that one has been on for..
maybe ride it a bit - see how your sprockets are?
dont really know but gut instinct says 2500 for the 203/204 a bit pricey? I got a new set of Bridgestone S20 hypersports for 2900 fitted? ( for my honda 600 )
the 302's were definitely under 2000 a set.
personally i think the 203/204 combi looks better tho - ie suit the style of the bike?
altho saying that - I really didnt like the 203 front tire on wet roads - could be that it was an old wore tire?? ... but the 302's do actually feel good on road IMHO
Discussion Starter #11
100% oil, i'll see what the shop says about break lines... the breaks felt okay.
Great, now i'm right confused - i love the look of the 203/204 but i need safety and traction... i need to ask around to see if 301/302 are much better in when then 203/204!! I've posted on the FB group - i hope someone can help.
I don't mind paying a little more for 203/204 but 500-1000k seems a lot!
Hi Nerk and Dub,
I've been reading this topic cause I'm also the lucky owner of a TW here in HK.
Nerk, your bike looks great, how is the tuning going on ?
I just bought mine a few months ago, it was also imported from japan in 2002.
It's mounted with TW203/204 tires, but they have some cracks so I figured it's a good idea to replace them. The shops I have visited so far only have the TW31/34 but I'd prefer to stick with the 203/204.
Do you know any shop providing those ?
Thanks !
Pierre
The Shinko 428 tires are great. Good for on or off road. Just air down for off road. Stay away from mud though; all though they will eventually get you through. I don't have any sand around to try them in; so I can't say about that. They really shine on road. You gotta know though; that most of my years of riding; whether on or off road was done using "universals" like Dunlop K70's or Pirelli's MT32 front and rear. I would love to have a set for my TW, but they are no longer available. JMO
Discussion Starter #14
Hey Pierre,
Congrats on the bike... I also wanted the 203/204, however Dub and a few other people talked me out of them... after riding around HK for a bit I would agree, the roads when wet are crazy slippery.... also the 203/204 are a bit more expensive, I know they are around but not as common...
You can check up on my bike progress here:
http://tw200forum.com/index.php?/topic/5079-low-budget-hollow/
I've put far too much money into it, but it has been a real joy to drive around..
Nerk
Thanks for your answers,
Nerk your bike looks great, I really like the 'all black' look.
For the tires I have tried several bike shops, around Tai Kok Tsui, Sham Shui Po, To Kwa Wan, they all call the Bridgestone dealer and tell me the TW203/204 are not available, only the TW31/34.
Even checked on the Yamaha shop on Prince Edward Road West today, the guy told me the 203/204 is discontinued from Bridgestone, which I find hard to believe since its not indicated on their website...
Since I mostly ride for leisure, I'll avoid going out on wet roads, the 203/204 seem more suitable for road than the 31/34... and I also prefer their look.
I haven't asked for the Shinko 428 yet but will try in the coming weeks.
Cheers.
Here's a picture of my bike when I bought it, I already removed the ugly cup holder on the handle bar, and the kind of metal support above the front light.
My link
Discussion Starter #16
I love the bike! Nice oil cooler too! I was parked close to a similar bike in Shek Kip Mei on the weekend, that wasnt you was it?
What did you pay for it?
Ahah thanks, no it was not me in Shek Kip Mei this weekend. I saw several bikes tuned in the same way as mine in HK already.
I've paid it 12.5k..
Cheers.
My link
bike looks nice!
know what u mean about the looks - but actually I started to prefer the Trailwings now! not that I buy tires on the way they look..........
those 203/4 were horrible in the wet..
according to the bridgestone site the Trailwings are a motocross "look" road tire... I had them on my CRM as well - and frankly they are not a good offroad tire! ( i run M603 /604 - but next time will try ED03/04 since they are road legal )
the Trailwings are good wet and dry, and seem to last pretty well!
if u really want the 203/204 u can always order off the net an pay HK$200 to have them fitted.. or buy tire irons and DIY
1 - 20 of 24 Posts
