OR.....is it possible your side stand is bent, neither of my bikes lay too far over ??Although it does lay over a bit, it’s better that way then to have it too upright that the smallest tip will knock it over
Center of mounting bolt to center of stand pad is about 12 1/2".Still waiting for someone to post the xt225 kickstand length.
Dam, the xt225 and xt250 use the same exact kickstand. I wonder why it is working for some and too long for others? My bike is definitely too unstable with this kickstand.Center of mounting bolt to center of stand pad is about 12 1/2".
If you look at both our pictures, we have different frames. My kickstand bolts just underneath my chain while yours is inches below. I see other differences in the frame too. Mine is a 2001. Unless that isn't a TW in your picture.Remember that the side stand is at an angle to the frame, so a couple inches of extra length does not amount to very much vertical change to the posture of the bike. If others are making it work, it will probably work for you, too.
It's a '94 XT225.If you look at both our pictures, we have different frames. My kickstand bolts just underneath my chain while yours is inches below. I see other differences in the frame too. Mine is a 2001. Unless that isn't a TW in your picture.
Dam, I thought I had it figured out.It's a '94 XT225.
