I installed my kicker last night and I have a few questions/tips.
Tip:
1. Starter does not have to be removed. I started to pull it based on the install pics on the web and its not necessary.
2. The clutch tool wasnt needed for me. Mine is a like new 08 and I just put it in 5th gear. Put the rear brake lever back in place and layed on the break while I lightly hit my impact on the nut. Worked perfectly and barely needed any power. To get it back on same routine but with a torque wrench instead of the impact. It was very easy to hold it and put 36ft lbs on it. Make sure 5th gear.
3. I was able to re-use the case gasket on an 08 with 2200 miles. I purchased a replacement but I didn't use it because I wanted to see if the original would hold up. So far so good. I also didnt need the o-ring for the clutch rod because it was in great shape.
Questions:
1. Why is the initial kick down require a bit of pressure? It seems like its locked up but when you stand up on it it goes and fires right up. I'm used to an older kicker that moves pretty easily. The TW seems to need a hard push for the first 1/2 inch of movement and then it goes. Is it just the compression stroke holding it back at first? This would imply it always ends up back at the compression stroke when turning it off because it does it every time. It makes sense to me that the engine when turned off would probably end up near the compression stroke because the pressure would stop the engine when its just about stopped. But I wanted to ask. I plan on pulling the plug and kicking it to see if its easier and that I dont have a bind of somesort going on.
2. Why does the kicker hit the foot pedal attachment on the end of the stroke? Not hard but it does. Is this normal?
3. I had to drill out the non kick start plug in the case and then pop it out with a screwdriver. It would come out on its own. Anyone else have this issue?
4. Why cant you re-use the clutch lock washer if its in good shape? I was able to bend mine back in shape and it seems like you could re-use it. I didn't but was wondering, is there a reason you must replace it?
Thanks everyone for any assistance.
Also, I got the slotted carb needle for the South American TW from Ron Ayers.com. I know a few people have been looking for this.
Tip:
Questions:
