Hi All-
I've searched the forum posts and not found anything regarding where one should add a kill button.....By 'where',I mean at what location in the wiring. I think that the only proper point would be to use a normally closed momentary button switch to interrupt either the white or the green wire from the signal coil. I don't believe that using the classic n/c kill button would be safe to use because it would have to short a wire to ground.....
Has anyone installed a kill button on their TW?
(To clarify,I am referring to an after-market dirt bike style of kill button.....)
They already come with one, red switch by the throttle....
"....They already come with one, red switch by the throttle.... "
That's a rocker type kill switch,I'm after a 'button' momentary type switch......
soooo....switching from one position to another as opposed to holding the switch in for x amount of time, takes more time to do.......what am I not understanding about this? Or its just personal preference to have a button to push and hold?
