Today I was riding and had my GPS on my bike and my speedo said 65 and the GPS said 60 so I guess whatever my speedo says I can pretty much take 5 miles an hour off that. Just wondering if anyone else's bike does the same.
10%?
My Bike is a 2008 and it has the stock tire on it.Sounds about right. Your speed should be off proportionally throughout the MPH range.
My 1990 is pretty much right on with my GPS.
Do you have an aftermarket tire on your bike?
All devices are accurate within a certain percentage. As an example, if your speedometer is correct to +/- 2%, gps +/- 1.5% and you have a front tire that is 1 inch smaller or larger than stock then there is quite a bit of room for error. Next time you see a policeman conducting a radar or laser speed enforcement campaign on the side of the road, stop and ask if he will verify your speedometer reading as you approach at a predetermined speed. Afterwards you can compare your gps to the known speed of the radar/laser . Keeping in mind these units are also only correct to within a certain percentage as well.How do you know your GPS is displaying the accurate speed? Are all GPS's equally accurate?
BTW, I'm not questioning anyone's judgement, I'd really like to know.
Mark
