My tw200 started running horrible. After doing some research on here I am guessing it is because I was an idiot and started using premium 91 octane gas..
..... I noticed that my petcock was leaking so i took it apart to check the gaskets and the one that goes between the tank seems to be the culprit.
My question is the procycle repair kit is$17.95, new petcocks on ebay are about $10.00. Anyone have any advice on new petcocks on ebay working?
After I fix the petcock leak do i need to drain the carb or if i refill with 87 octane will it be fine?
should i run seafoam through it? i see that recommended a lot but have never tried it.
thanks
thanks
